John Pollman
- Rochester Hills, MI
Yep, strips and rails to come.I recommend that you add some anti skid step tread strips every few inches after the finish is applied, so the wheelchair wheels have something to grip to, but you likely already know this. Great project so far. It should be perfect for your need. No edge quide rail? Maybe a few inch high strip along the edge would be a good idea to keep your wheelchair wheels from falling off the edge.
My son's ramps are all aluminum with the anti slip strips to keep his wheelchair from slipping. They have 2" high aluminum side rails, and he has bent them some a few times from minor crashes.
The ramp is 4 pieces of 3/4" Baltic Birch on edge, covered with 1/2" Baltic Birch, and then 3/4"x2-1/4" White Oak flooring.Hi John, looks good. What did you use for the bottom of the ramp? I needed to come up with a ramp with a platform outside the door onto our deck after the deck was redone. I used materials left over from the deck redo so I only had a limited amount of materials to work with. I didn't want any exposed fasteners but I couldn't figure out how to do the lowest couple of planks because there wouldn't be enough material the screws to hold. I ended up with a heavy rubber ramp and although it's got more texture than I wanted, it does work. Picture here.
