allen levine
- new york city burbs
the amateur says cut the walls on a 45 degree angle on the tablesaw.
easy, then glue and use 4 screws on each side, only putting the screws under the areas on top and bottom where the top cove and bottom base mouldings will cover. the screws will not be seen, noone will know they are there, only you, and it will hold the box together as tight as anything.
The work seems to be in the finishing area of this blanket chest.
(then Id use a few carefully places screws on the inside, to hold the mouldings in place, along with glue, then use a small brad gun and glue the cedar over the inside wood, again hiding all constructions screws.
Best of luck with the finishing.
