Rennie,
In my opinion the tablesaw,bandsaw, jointer and in my case the drill press is out in the center.
My bandsaw and drill press is configured around a support post in my shop (
http://www.superwoodworks.com/images/InsideShop/ShopShots/ShopShot11.JPG &
http://www.superwoodworks.com/images/InsideShop/ShopShots/ShopShot01.JPG )
which does not actually cost me any room but allows me to work with long pieces when needed.
If you do not work with long pieces on your table saw then the construction table and bandsaw behind your table saw may work for you.
At one time I had my construction table (non moveable)behind my table saw for convienence but whenever I had a project on the table it seemed to interfeer with the tablesaw. Just swinging a long board or cutting a sheet of plywood.
I would try to keep the construction table in an area that will be clear of material that needs to dimensioned which will help to avoid accidental damage to your current projects. Believe me I am speaking from experience.
