How to question...... /blade tensioning
People,
I have to admit to not releasing tension on by bandsaw blades except for blade changes too. That goes for metal saws as well as wood saws. I have never had any problems from it either.
I also installed orange urethane tires and a powertwist belt on my 14" Delta bandsaw with very pleasing results.
My original equipment lower upper tire, which was not really flat (both tires were not that great) and made the blade bounce, let go one day and that was a noisy eye opening experience.
I had already seen how the orahge tires worked so I got a pair. Good investment. That was about a year ago and the tension has been on the saw nearly all the time except for about 3 blade changes. I have looked for any impressions in the tires from leaving the blade tight all the time and sometimes even not using the saw for weeks has not left any marks.
I am thinking, maybe those tales of needing to release tension are not all that important. I do use decent blades like Olson and Timberwolf. I never used any of the higer class blades yet, but never had a blade break or other problems because of tensioning.
When I was "growing up", using my first bandsaws, both 12" Craftsmans, I used Craftsman blades, and did have a few break, mostly at welds. Figured they were cheaper blades. I never detensioned either of my old saws either. I'm talking total of over about some 45 years history.
Did I wander off topic here some?
Hope not. So, I guess my opinion would be to forget about releasing tension on your saw.
Aloha, Tony
