Once I got the blast gate done, I put the wye back in place......
Man it JUST fit, let me tell you, no space to spare
here it is open.
I did figure out, that I would not be able to put a second blast gate into the wye, but not before I cut a slot for it
Oh well, that will get covered up when I put a regular blast gate in there.
These are a couple shots of the area behind the saw, where the flex hose comes out, I think that with a pan in there, making the flex hose area the low point, sloping back to the flex hose, and the shroud around the saw, I'll have a pretty good way to collect the dust.
When I was grinding the slots for the blast gate (one of which I'll not need) my el cheapo 4" angel grinder let the smoke out
No big surprise, it was a $29.99 special, and the last of my cheap impulse buy units. I really did kill it the other day with the concrete floor grinding, that was hard on it, but today, it just did not stand up the regular use. The case on it is plastic, and I abused it so much that the plastic around the bearings melted, which let all kinds of other problems happen, my own fault, using a cheap tool like this on the job.
I went down to a local place, I happened to know they were having a sale even, and I bought a replacement, I hope this one lasts longer (the cheap one did last a fair bit, maybe two years). It was regular $80 on sale for about $50, not bad I guess
it is a name brand Hitachi, and it is has an all aluminum case.
I did notice one thing...........
....... yep, NOT made in Japan
OK two things, the other is that it is rated for 30 minutes of use.
