Bart, I'll put a piece on the edge of the blast gate, to make it easier to grip, but I don't think I need an extension, it is not hard to get at.
I got a lot done so far today..........
I started by building a frame for the pan under the saw, this will stay in place, and keep most of the dust, I hope, off the jointer..........
I uses some lightweight tubing to build a frame to hold the pan, it is not very robust, but it does not have to be, it is fairly tight to the underside of the sliding table.
I then put a pan under the saw, it is just some sheet steel, and I used the aluminum tape to seal it off and cover any gaps........
The tape is actually quite smooth, but in the picture, each facet reflects light to make it looks very bumpy.
Here is some more details of the right side surround.......
With the saw at a 45, there is lots of clearance, but when you put it to a double 45, it would interfere with the surround, so I put the last bit of the surround on a hinge..........
This way, I can do the double 45 cut with out anything hitting the saw.
I've yet to build the left side, that is next, should be easier than the right side, more room. Even with just the back and the right side done, it works well, the majority of the dust is collected, the pan might build up a bit, but all I have to do is slide out the saw table, and use a brush to push the dust towards the inlet.
Once the surround is done, I have to look forward to solving the problem with the DC to the jointer, this is what I have now.......
........ certainly is going to need some reworking.
