Jim Bergstrom
- Nanaimo B.C. Canada
Really appreciate your posts Alex, thanks for sharing
Larry-once again you made a great chapter alex now you mentioned that you normally cut the pins before the tails and in this case you didnt why was that?
Great info, post, and pic Alex!
Nice Japanese chisels and saws too!
If you ever need some more, just tell me, I can get you some local!
I drink it cold and all year around-I buy my blades at Highland Hardware in Atlanta-a blade last me at least five years,unless I break a tooth-I pay about $25 for the short blades and $30 bucks for the 9" --- that auction sounds good and I would like to find some off-set chisels--but I don't read Japanese---Alex, in the winter I very much like the Nigori Sake warmed up, kind of a meal in a cup in the summer I prefer a drier sake that I can enjoy straight, on the rocks!
I supply myself with sets of Japanese chisels off of Yahoo auction here (Like E-bay over there) and they are often in need of some TLC, but for the price, you can't beat the deals with a stick!
What do you pay for the replacement blades in you Japanese pull saws?
...I buy my blades at Highland Hardware in Atlanta-a blade last me at least five years,unless I break a tooth-I pay about $25 for the short blades and $30 bucks for the 9" ---
alex
I was using that chisel because the thickness made it easy to photograph--I also use a 8" wheel for my turning tools but would never use it for chisels are plane Irons-I hardly ever burn a tool with this set-up also when I grind I keep my fingers right there where I'll feel it start getting to hot and of course I have a little jar of water and after three are four passes I'll dunk it-if I should burn a tool it will be at the corner-I'll grind it back blunt past the burn and start again----but that never happens-As always, looks great Alex
That chisel you are sharpening, that is one stout mortising chisel, we are seeing fewer and fewer of them around here for sale.
I use an 8" slow speed grinder for my turning tools, but I certainly agree with you that the 6" wheel is better for regular chisels!
larry-it's a 60 grit wheel-thanks alex for the detailed pics of how you do it,, i have a motor that is destined to do as you have shown.. much more economical than a brand name specailty rig.. what grit of wheel are you using?
