edward alexander
- smithville,tx.
part three-
i nearly always use dowels for side joints, as much for keeping the boards lined up when gluing as for the strength - i drill nine sets of 3/8" holes in each board-
to prepare the dowels i take a 3/8" dowel rod and with a with a little plane take two shavings off opposite so the glue at the bottom of the holes will have a getaway also i cut the dowels just a little short-
i have two bandsaws and could cut these 27 dowels in a fraction of the time it takes to do it by hand but like i said i'm not in that big of a hurry and besides i need the practice - i use a sharp chisel to point the ends-the little curved riffler off to the side will be used to slightly point the other end after they have been tapped in-
all 27 tapped in-each hole has a drop of glue-
before i glue it up i made sure all my ducks are in a row-
glued up-
later in the day i take my new walnut desk top out of the clamps and it don't look bad-
some answers-larry- iv'e been doing this for awhile
chris-later i will show how the legs will be attached.
more to come-----alex
glued up-
