Bart Leetch
BTW, we were gone a day and half, look what I stirred up.....
WOW I don't know about someone that would stir the pot & then run.
Have fun Frank its quite easy.Just let the old dog lay.
Well you take some paper see & spread some good wood glue all over the dog's back & apply the paper the add more glue on top of the paper & put the wood disc on top of the glue then take a base ball bat & beat the living daylights out of it. I doesn't do you any good & the dog doesn't like it either
At least the last sentence makes sense.
You can "finish" it Vaughn, and as long as your waste block matches your foot (mates well together) you should be OK.
I think the biggest advantage of block gluing is not losing thickness of your blank by not needing a tenon.
Vaughn
You can turn the back side while mounted to the glue block to form the outside of the concave, then using a jam chuck & if need be bringing up your tail stock & turn & shape & clean up the inside of the concave.
I've tried hot glue on an aluminum faceplate with varying degrees of success and some launches...
How 'bout them Red Sox?
Frank, you could always opt for the double faced turners tape. That stuff holds a ton.
Well you know if you weren't hiding behind that mask we'd know who we were talking to. I know your crusading for truth, justice & the Tasmanian way but masks are kind of out dated.
Again, it is not the best way but it worked for many years and if you look in some of the older turning books you will see it described.
