attic fan might need replacing
Frank Fusco
Our attic exhaust fan started making noises yesterday. It is not a whole house type fan, just one that takes heat out of the attic. Of course, it is roof mounted. And since I have 99% sworn off ladders and 100% sworn off climbing roofs, this will have to be farmed out.
I don't have a clue how big (meaning costly) this project might turn out to be. Not even sure what kind of tradesman to call, electrician, carpenter, or what. I'm not comfortable with a do it all handy man. Some are probably great but, ye jest don't know with unlicensed types.
Advice will be welcome.
Turn it off and don't replace it. That is my advice.
You can't pull enough air through there to cool the attic down any noticeable amount. And while I don't know this for a fact, I have read that it costs more to operate the fans than you save.
I turned mine off this year and I see no difference in my cooling bill. As long as moisture it not building up I don't see where your gaining anything.
Interesting take on the fan situation. I was watching it for a while, it didn't come on but I definitely could see heat waves emanating from it.
Our house is so energy efficient it is the envy of many who see it and learn what our utility bills are. Only one, the electric, about $120.00 a month levelized year round and that includes the well. That tells me the guy who built it knew what he was doing and may have had faith in the electric fan. Appreciate the input.
Frank,
I have to disagree with Jeff on thinking that the attic fan doesn't do much to help cool a house. They do, and although yours is making noises now, I would think it's probably just a bearing going bad. Seeing the heat eminating from the fan with it not running proves there is hot air moving out of the attic, and if the fan runs, more heat will be moved out. The best setup of an attic fan is in conjunction with gable or soffit vents.
Not knowing just what fan you have up there, it's hard to say if the bearings are the type that can be lubricated or just have to be replaced. If they are lubable, a service call would take care of it, for a couple years more anyway.
But, you saying you don't go on roofs, places repairing the fan out of the question, because hiring someone to take it down so it can be repaired and re-intsalling it will cost too much. Just have it replaced (if you can't just lubricate it) and save the old one for your shop, after you repair it.
JMHO
Aloha, Tony
Frank,
JMHO
Aloha, Tony
The fans run about $150.00. I got a 'guesstimate' from a contractor friend. He thinks the labor shouldn't run over $100.00.
I've seen exhausts like this before being installed and don't think mine can be lubricated.
How big is it? How much room in the Attic? Often, some of these are covers on the outside and fans are located with access from inside. If this is your's, simply go up there at night after it cools down and see if you can lube or replace from inside...
It is similar to this: http://www.shophmac.com/broan-350.html
I'm sure it will require some outside work.
I've never been in my attic, the only access is a small scuttle hole in a closet. I might poke my head up there and take a look.
Looks like it might be do-able from the attic. BTW tasks like these are why I raised an Electrician son and a handy Grandson.... "Hey guys, want help your old PaPaw?"
The installer guy just left, $100.00 richer for about 30 min. work. Oh, well.
I bought the exhaust fan at Lowe's for $118.00.
When I hit the breaker switch he said hot air was coming out like crazy. Much more so than just allowing it to vent. I'm convinced the power fan is the way to go. Especially so since the auto control thermostat is also a humidistat. It will power vent even in cool but humid weather. Sounds good to me.
I got curious and Googled it up and did some reading. No firm answers but looks like the more insulation you have in the attic, the less effective the fans are. Apparently fans can cool it some, the question is it enough to pay for the electricty to run the fan?
The one I found the most interesting was a study of solar powered fans. The conclusion was it worked but it would take 20 years to save enough money to break even.
Might not interest anyone but me but I found these three interesting reading.
http://homeenergy.org/archive/hem.dis.anl.gov/eehem/00/001109.html
http://www.clarkpublicutilities.com/yourhome/freeResources/energyAdviser/archives/2009/072809
http://www.uwex.edu/ces/news/cenews.cfm?ID=1062
I know we didn't save any money, or energy, last night. When I woke up this morning (I wear earplugs to bed), I heard the fan running. And, the outside temp was about 55 degrees, the fan shouldn't have been running. So, now, I'll have to get up in the attic and check the setting on the control. Won't be fun. But, if I fall the ceiling should break my momentum and with luck I'll land on the sofa.
LOL Welcome to my world. But I would still rather do an attic than the darn crawl spaces. Of course last week I had one I had to imitate a contortionist to get into and out of the attic.
Well......I learned a couple things today.
I went into the attic, first time ever. Found it has lights, that's good.
Adjusted the therm/humid-stat then looked up at the fan.
Bad news. It is mounted about 50% over the hole. Way-way [expletive deleted] off-center. I had thought it sounded like something was wrong. It was being overloaded not being able to move as much air as it was designed to do, struggling.
I called the contractor, he kinda fumbled with words and admitted he knew it had been mounted wrong. Claims the old one was that way. Hard to believe. If he had pointed it out to me as the job was being done, I would have been appreciative and willing to pay more to fix it. But, now, I'm thinkin' it may just be an excuse to do a quicky job.
Ennyhow, he came right out and is up there now fixing it. I have some extra shingles he can use for the job.
I hate using the drill sergeant voice :mad: but it seems necessary when dealing contractors.
How did you Fair? Well, I hope...
The kid that installed it came out within the hour and redid the mounting.
We got to chatting afterwards and he told me the trades are slow lately and he has only earned $150.00 in the past three weeks, $100.00 of it from me. I'm sure he was fishing for more money but I felt rewarding poor service in the first place was not justified. And, I'm certainly not in a position to become a charity.
However, I adjusted the temp and humid settings myself and all is well now. I hope all is well, if it leaks at the first rain we will be having more conversations.
I should have taken a picture of how it was mounted in the first place. The whole thing, including the motor was only 50% over air, the rest over roof. I'm pretty certain it would have burned out quickly if left that way.
