Dave Black
- Central PA
You could probably do a 1/2" or 3/4" PVC distribution system much cheaper. I did a 3/4" schedule 80 PVC system in my shop then I added some more stuff and used schedule 40 PVC. I believe 3/4" schedule 40 max pressure is 289psi or so which is about 2 times what most compressors are set at and the bursting pressure is WAY above that. http://www.engineeringtoolbox.com/pvc-cpvc-pipes-pressures-d_796.html
