ed sautter
- Cortland NY
Ted great work thus far. Keep it up.
Hi everyone
Just got started again after a 6 month break, Overseas holidays and other excuses,
The motor I used was a radiator cooling fan of an old toyota car, seems to work very well, BUT, I did have to make a very small 25mm pulley to gear it down enough,
the belt is 5mm rubber Oring material, you can buy it by the metre, and join it with superglue, I use Loctite 406.
Now for a question! I have just finished my first lot of pipes (accompaniament) but i cant tune pipe D#, I can get D ok but the needle on the Korg tuner moves to the right and then changes to E, I have adjusted every part that moves, and changed the thickness of the card to no avail, is this importent, or can i leave it just before it changes to E ??
thanks
Graham
Auckland NZ
Ted I will have to look on my next trip to the old house I still dont have the shop moved. I just went to a vacuum cleaner repair shop and looked at the belts and picked one out and made it work. I do have some in stock if ya want me to send ya one. I can also make one up for ya out of orange round belting 3/16" or 1/4"
