Some lessons learned
Ok, so here is a quick recap of what I learned last night:
1. Need a waste block - in a big way do you need one.
2. Turner's tape works well on small stuff. I saw the thread about using hot glue so I'll try that next session.
3. Sharp tools are a good thing
4. Boy does it wiggle all over the place when off center - I 'knew' it would happen but wasn't prepared for just how much it would walk the lathe. I have 2 lathes - an old Carba-Tec mini and a 1936 Craftsman monstrosity. I put it on the Carba-Tec with an adapter and when I went off center, I had to rethink my decision!
I didn't want to sacrifice any 'good wood' so I cut a piece of 1x3 pine and taped it on. Below are some pictures of the mess I made...
This is after I just started to shape up the block:
Here I moved to the 1st offset hole and drilled:
Ok - using the smallest gouge I have (1/4"), I tried to turn out the lanyard hole:
And here is where everything fell apart - trying to use the offsets:
SO - tonight I try again using some walnut I have. I want to make coasters using the walnut and it may be easier because I don't have to turn the lanyard hole...or maybe I just need a LOT more practice.
OH - and need to refer back to #1 above
