Three parallel clamps reversed as spreaders make the table setup go pretty quick:
This 3/4" board started out as a 2x6. I've got a couple more that I'll run down to paneling to warm her up:
The marks I was worried about when taking small bites only show up if I run the board through twice at the same setting. It seems even the smallest increase in depth eliminates them so that makes me happy. Larry was right, on this 2-by at least there is no difference in surface quality regardless of direction. I'll run some good stuff after some more tweaking:
There was a bit of snipe on the left side. I re-checked with my poor-man's-Rotocator and sure enough, the leading bed roller was high on that side. I adjusted it down and everything is just dandy. The speed shift is reasonably smooth. At first it seemed hard to shift but I realized there is not real "thunk" from one position to the other. Once I figured that out it was fine.
My modified (oversized AFF filter on top and solid bag on the bottom) 1HP Delta does fine on gathering the chips. I actually seem to get less "blow by" than I did with the lunchbox unit. If I had any issue I would just add a drop to the cyclone which would take care of it I'm sure.
So, all in all, very satisfied; everything showed up and was in good shape. It went together easily except for filling the gear oil chamber; what a pain. The adjustments are pretty straight forward using eccentric bushings or threaded rod with setting nuts for the adjustments; no struggling to hold something "just there" long enough to tighten it down.
It is soooo much quieter than the lunchbox. Runs very smooth. I have a reminder on my calender to check the belts after whatever the interval is in the manual and a note to change the gear oil at the specified interval as well. 30 years ago when I used to split tractors for a living I learned the value of liquid honing and the price for not changing your fluids when you were supposed to ;-)
P.s. the machine stands on two steel wheels and two large rubber feet when the mobile base is "locked". My planer uses the same mechanism and stays put well. You step on the lever activated front wheel to raise the rubber feet up and away you go.
