allen levine
- new york city burbs
that is one big cross. .
Thanks Don and Vaughn i got a better handle on it but could not understand how those two metal brackets will work. Not to worry.
Don how about a better picture of just the cross lap joint. I will be watching ... thanks
Rob, here is a picture pf the half lap with the other half not shown for clarity
The lap is 8 inches wide and 4 inches high. The only weight that the joint needs to support is the weight the of the bottom part of the cross and the corpus which together is less then 150 lbs. The 5 foot cross piece is attached directly to the 4 foot cleat and there is where the forces are.
of e
hey don, why didnt you keep the cross section in one piece?? rather than two pieces like you have just curious???
Larry I needed a finished 10 foot height so the raw material needed to be a 12 footer. There wasn't a 12 foot piece of 8/4 hard maple anywhere in Arizona. I searched for a week.
I bet you could get several pieces no problem once this one is completed.
Looking good! How did you do the half lap? Did you use a router or a sled on the tablesaw with a dado blade?
