scott spencer
- Rochester, NY
Got a question for you folks who've used lacquer before or have a good rub out process. What's your method?
If the surface is curved and not too big, use the orange compound from the auto parts store. I think it's called rubbing compound and the white stuff is called polishing compound. Rub the same way as described above for the polishing compound.Excellent! Just the info I was looking for....thanks guys!
There's probably 6-8 coats on there so thickness shouldn't be a problem. Any additional tips if the surface is curved?
Mineral Oil at the drug store.
In the laxative aisle...
