Yeah Cynthia the kit Carol mentions is the one i bought. It also gives you top of the table heightadjustment.
This
is it here but shop around for it if you interested in it.
There is a bitter sweet side to this kit though. The value engineering guys at Delta keep messing with good product. So i did a bit of tweeking to the inside of the castings on mine. Maybe i should have taken it back but i knew no better at the time so just soldiered on.
Its a really great starter kit. All the features Carol mentions are very very true and useful on this setup. I have the fixed base attached to the phenolic lee valley insert and my top is baltic birch configured on a (oh man had a gray hair moment there) torsion box type structure. It has stayed flat for years and its a portable table. I plonk it into my router table cabinet.
Buy a kit like this refurbished for under $200US. You add the LV insert and for what $250 you in business with a very nice setup. Only two accessories i would add are the book
and a vac port for the bases. Check out this link to CPO refurbished you could save enough dollars to pay for the book.
One other thing in general that i would advise you, is check out the manufacturers website when it comes to tools and machines you buy. Make sure of the support like parts lists manuals and accessories. You will notice if you look at the Delta porter cable link i have put at the top that you can get to see exploded views of the tools in parts list pdfs available on line before you buy. Not every supplier provides this kind of support. You need it sooner or later. Its what gives your purchases longevity.
In my mind after what i have experienced, given your experience i would set a goal of starting out with a kit like this and not expecting to go at it to make something that requires routering until you have messed around a bit and got familiar with the general run of the mill routing.
I keep saying BUY CAROLS BOOK. It will walk you through the process in very good well written plain language that is easy to understand. You will be able to see the inside story to this world of routing. Walk through the book trying the various projects. Build some jigs, buy some acrylic and make some extension bases get a feel.
Then survey the landscape and start a decent project. When you do make sure to have extra material prepared and do test cuts to check your setup and make trial runs.
You mentioned a budget of $750. Put it in the bank.
Be prepared to spend a few hundred. Save the rest for when you got your own feel and are in a position to make better self decided decisions.
The great thing about this set up mentioned is the fact that you get all the bits and bobs in one hit. Fixed base, plunge base, above table height adjustment and whats more you can buy additional bases if you make dedicated jigs. then you just bounce the router motor core from one to another.
Remember this is not going to be the last router you purchase. Be prepared for that. There is no singing dancing all in one router that will do everything appropriately. One day you will want a trim router that is palm size (i dont have one yet but its on my list) then you will want a huge monster power wise for your dedicated table.
Take some advice from my wife, a fellow of your species. She says "Rob" remember its a journey. You dont get there in one day.
I keep reminding her that I would like to get there before i can no longer hold the router though.
Good luck keep us posted, and lastly set aside some money for the bits. Otherwise you will be like a turner with no lathe chuck and only the faceplate they sold with the lathe and still no chisels. How they do that i dont know?
