Tony Bilello
- Kemah, Tx. - Houston Suburb
Dave as with any coats of anything the wood will take on the natural look and be darker when you apply the finish. Take some Lacquer thinner and wipe on the wood you will see the natural color. With Lacquer as a finish the color you saw with the thinner is the color you will get with the lacquer finish. It will be a truer color finish then any other product unless you use a Acrylic lacquer finish, that's the closest to clear that I know of.
I agree 100% with Dave Hawksford.
Now, I would also like to clear up one misconception on finishes when it comes to the term "Clear". "Clear" means you can see through it. It also means a slight ambering, they just don't explain that part. With no ambering at all like in an acrylic, the correct term is "Water White".
"Clear" is normally a desireable feature because the slight ambering gives the wood a more natural warm color to it. If you put "Water White" on say for example, red oak. The oak looks lifeless. It looks exactly the same as when you sanded it. "Water White" like in acrylics are desireable when you are using colors like, red, blue, green, etc. This is where you dont want that slight amber to change your color.
Hope that thoroughly confuses you
