Mohammad Madha
- Los Angeles, CA
Glad it was just a close call. Time to go over the saftey procedures.
out of curiosity, would that have triggered a SawStop?
Really guys, cutting a finger off is not all that bad.
Have you cut off a finger Larry? If not, then upon what do you base your statement?
I tend to concentrate 100% on what I am working on and am oblivious to what is going on around me. Both times were the same cause, I was startled. And I jumped the wrong way. I'm one of those wide open all the time sorts and as such am a bit jumpy.
You would think that people would have enough common sense to not do that, but I am here to tell you they don't........
I have never seen a sawstop demo where the send the hotdog into the blade in that situation. I'd be curious if it is fast enough?
I figured it out one time how fast a piece of wood is traveling when you get a kickback.
If it gets full traction, and they usually do, the piece is traveling at around 110mph with most tools. Thats going to hurtif it hits you, and if your hand is holding that piece on the wrong side of the blade, I'm sorry to tell you, you are not that fast.
Thats what got me last time. I was using a captive jig to run through parts for a crib with a 3/8" dado blade and when startled I have no idea how that thing got me. Someone came up behind me and tapped me on the shoulder and the next thing I know I lost weight the hard way.
The first time I was cutting parts on a chop saw, and someone tapped me on the shoulder and I jumped, the wrong way.
...Can anyone speak from experience on this? Have you seen a "high feed rate" demo ... or done it yourself?
I've seen a few demos in person, as well as a slow-motion video online. Most demos use a "reasonable" feed rate and result in a small scratch - if that. I think you'd be hard-pressed to chop off a finger (on a SawStop) even if you jammed it into the blade as fast as you could.
