No Cynthia...I'm not. It's worse now than when I came home and I' ve had it. Back to the hospital in the morning for more invasive testing. I'll let you all know how it turns out.
Thanks for all the kind words guys. It feels good to do something besides "rest and get better"
This is a nice click 2mm pencil from PSI. Can be easily made as a one piece pencil by eliminating the centre band.Yeppers, it's the 2mm lead.
Nice job.
I've got an Artist Pencil kit from Rockler that uses a 11mm brass tube, I have an 11mm bit but I'm having trouble finding a 11mm shaft for my pen mill.Hi Jim; I'm fairly new to turning pens as well! Here's another way to square the blank that I use at times.Does anyone have any ideas on how to square the end of the blank?
Select the nearest punch size from a Transfer Punch Set http://www.leevalley.com/en/wood/page.aspx?p=54892&cat=1,43456 that fits inside the pen tube that you want to square up.
Secure that in a drill chuck on the tailstock. With some double sided tape, secure some sandpaper on a faceplate on the headstock.
Turn the lathe on slowly and inch the transfer punch on the tailstock very close to the spinning faceplate. Tighten the tailstock down and holding the blank flat on the transfer punch, slowly move it towards the spinning sandpaper.
They say "A picture is worth a thousand words". Here's 2000 words!
They're a little blurry, too much hurry, but I think you can get the drift!
