Gary Zimmel
- Stony Plain, Alberta
A Cap Goes On.
With a little shop time tonight I got one of the caps on.
I have two options for my dowels.
The first is to rip some strips and rough shape them with a chisel then put them through a dowel plate...
A lot of work to me.
The second is to buy an oversized dowel and put it through the dowel plate.
I hunted through all the dowels at the lumber store and found what I was after.
Cut a bunch to a smaller length and then fired them through the dowel plate.
I now have dowels that are a consistent size...
Putting on a high tech depth gauge we drill our holes.
After the three hole are drilled I have to elongate the outer ones to allow for movement.
Quick and easy all I do is rock my drill back and forth and then clean it up with a round file.
Glue on only the middle mortice. The middle dowel gets glue on the whole dowel.
Outside ones have just a bit on glue on the last 1/2" to just hold them in place.
After we cut these off we will finally call this leg done....
Hope everyone is getting some shop time.
