Alan Bienlein
If you think about it you are making a cut in wood then filling up the same cut with wood and glue. I don't think that you are compromising the strength of the wood at all by going halfway with a dado.
Some aint gonna like it but My Festool makes quick work of them. It's all in knowing your tools and how to set them up right.
I'm staying with the half the thickness. So far the best argument is the easy math but I can add 3/8 just as easy as I can add 1/2 And while they say an end grain glue joint is not as strong a bigger weak (achieved by a deeper dado) glue joint is better than a small weak one.
While I'm at it, an option I've used on some dado joints is making the dado narrower than the mating piece. For instance, when mating a 3/4" shelf to a cabinet side, I'll use a 1/2" router bit to make the dado. Then rabbet the shelf so the end fits nicely into the dado.
Does this have an advantage over a full-width dado?
Never found a compelling reason to go more that 1/8 deep.
well guys and mike specifically, i fully agree with you on the full sheets and trying to hold it down.. i used a router on this project last month worked much easier than TS and the only complaint was getting a tight fitting joint. which i did get on all but one small section. how do you maintain the tightness mike for said shelf thickness?I machine dadoes in ¾" stock ¼" deep. I like to leave ½". I don't use a TS, but rather a handheld router, and a jig you can easily make.
It's faster than doing them on a TS.
It leaves your TS available.
You aren't machining face down subjecting the stock to tearout.
You can see what you're doing.
The dadoes are clean with flat bottoms.
You don't have to force press sheet stock down on the TS table. This can be a strain with large sheets.
See the jig here.
