- ABQ NM
Ditto what Bart said.
frank, grease in the wrong place can cause you major headaches it attracts and holds the saw dust which can bind up your adjustments..
.... I'll need a male plug to my lathe box. Those are more expensive than someone quoted. It will be about $35.00. I'll shop for a switch today and call a friend for back up assistance. Final report later.
Frank, don't forget that with this new motor you are doubling your rpms and this will double your blade speed (unless this was already addressed and I missed it). I'm not sure I'd be comfortable with my blade running twice as fast. But that's just me.
With you now. I checked and, by golly , the drive pulley is larger than the motor pulley.
So, tomorrow I go shopping for a new smaller drive pulley. Having a lot of trouble finding parts locally. If I can't find one I'll just switch pulley temporarily until I do find one.
Appreciate the concern 6900 rpm would be potential bad news. I like my face and fingers.
So, tomorrow I go shopping for a new smaller drive pulley...
Frank, please, we already went over this. The motor pulley is always going to be larger than the arbor pulley, the question is, how much? Stop going off half-cocked and just figure the proper course of action. Just go measure them and do the math.
See my post #25 in your old thread (HERE: http://familywoodworking.org/forums/showthread.php?27673-new-old-saw&p=340204#post340204) and just do the math. It will take longer to take the measurements than to punch the numbers in the calculator... but then you'll KNOW the answer.
Best of luck Frank, glad you got it measured and sorted. Looking forward to some good news. And btw if you need a pulley before you buy give me a holler i got a couple of spares. Have no idea on their size but will check if you need and happily send em to you.
Link belt might also be a nice upgrade when the tool budget permits.
OK. My motor pulley measures 1.75" in the groove, the blade pulley measures 1.50". The 'rithmetic says my 3450 rpm motor will spin the blade at 4036 rpm. Looks like it is right on track with that. Plus the 3 hp. will give a good cut, I'm confident.
Hoping the switch arrives today.
