That will depend on the size of the dust. Planer chips, not as often, mdf and sanding, a bit more. I glance at mine each time I empty, but usually knock what is there anyway. Mine is just held on with bungees, so easy enough to do
Mike, my filter is the 80/20 blend. A lot of my dust collection involves sanding at the lathe, although I also use the 4" flex hose as a giant shop vac sometimes to clean up curlies from the floor after a lathe session. (If they are long and wet, I'll generally sweep and shovel most of them up, but I still usually finish off with the DC hose.) I usually tap the filter (or hit it with compressed air) before I empty the bag.
