hu lowery
probably won't play with stabilizing when all is said and done, tempting but scary
Frank,
The resin I was speaking of is the Cactus Juice. John can tell us about that. The other stuff is being bought in bulk by a supplier and has no name, none given to be more accurate. He has handled Nelsonite and Resolute in the past, seems happier with this stuff. Like you I am skeptical of the "goes a long ways" if you soak a piece of wood. I was amazed at how much air came out of a less than one inch by thirty inch dowel when I soaked them in Resolute. I'll probably look into the plexi-acetone myself, and eventually do nothing. These things interest me and the things that form a plastic like the juice and I assume plexi-acetone are probably pretty stable. I don't feel real comfortable turning the liquid soaked wood or putting it in someone's home. I am concerned with degassing issues. May not be an issue, just outside my comfort zone.
Hu
Plexi/acetone is inexpensive. Even punky wood, when stabilized is very strong, after all, it is mostly plexiglas. Consider, it soaks into the wood. The "go a long ways" comment can only be marketing puff. You soak it into the wood and that volume is no longer in the pot. If you use it, do with ventilation. I don't know if the fumes are hazardous but after a while the 'orangy' odor became pervasive and sorta sickening. Let us know what you do.
Frank,
Hu
