- Constantine, MI
I'd second GOOD casters, that sucker is HEAVY.The other gotcha with the A frame rack setup is getting to the pieces in the ends, the one end faces into the room the other end I have (almost) against a wall so you have to pull it out to get at those pieces.
For the bench cart my main concern would be how to lock it in place.
like jans idea rennie but make sure you can see the pieces and get access to them on the side needed or you will just be filling space and not using the shorts on the next project.
Rennie this issue invaded my space recently after I purchased what was a whole cherry tree that had been cut and air dried. BTW never do that.
I think its a really neat solution and you can make the shorts bins suite your needs.
Just one thing if anyone does this, don't skimp on the castors. I used 6 off 3 inch cheapo Chinese rubber and I got to change them out. When full as the rack is now, it would not move on concrete floor.
Tres Cool! And when that one gets full?
I have some 4" casters that I had under a previous lumber cart that held a lot more than this. They were pricey, but did the job. They also locked pretty well.
The open end of the storage unit faces into the shop next to my drill press. Should be easy access. Sheet good storage will be twofold, Large against the wall and the bench will go up against them, and I/m thinking of a shallow storage area on the back of the bench for smaller sheet goods. Not sure yet.
