Results 1 to 9 of 9
Thread: 15° router bit
    Oct 2011
    Cortland NY
    238
    15° router bit
    Anyone know where I would find a 15° router bit that comes to a point. Looking to use it on the CNC at the shop for a commercial job I have upcoming. It needs to come to a full point. Otherwise I would need to scab on a waste board to it as I need a full cut. Material thickness is 1/2". Any ideas would be great.
    I've seen veining bits with a 45° tip but this won't do.
    5,068
    Katana® Rabbeting Router Bit Kits, Round Nose / Core Box Router ...
    www.mlcswoodworking.com
    12,081
    dont know about 15* but here is a pointy one at 60* from LV
    http://www.leevalley.com/US/wood/pag...=1,46168,46173
    and a non pointy
    http://www.leevalley.com/US/wood/pag...168,46173&ap=1
    both for sign making
    East Freeetown, Massachusetts
    2,898
    You could take a look at
    Harvey tools
    Criterion tools
    Beckworth may make a special tool for you, but I am sure it would be pricy
    I don't recall seeing cutters that come to a sharp point at a 15 degree angle
    2,898
    This one ALMOST gets you there.
    http://www.mlcswoodworking.com/shops...-Groove_Anchor
    I use MLCS for "V"-grooving a lot of the time - I have good luck with them.
    May 2011
    Cape Cod, Ma.
    1,553
    Ed would this work for you?
    http://www.eagleamerica.com/product/v133-0402
    Another thought and one I have been known to do in a pinch is to remove the bearing and carefully grind off the threaded post below the carbide
    Oct 2011
    Cortland NY
    238
    Thanks guys for the help. Sorry I didn't get back here and give you an update. I did find a bit that works really well for the job. It was in the degree that we needed in the first place. Got it from Eagle America and is http://www.eagleamerica.com/product/v132-1022/s . It is the 22° bit and works just as it should. We can produce the little corner pieces with this bit and a 3/4" core box cutter on the CNC and get that 1/2" x 1/2" x 1/2" triangle that work well. So material is in the house (400 sheets or 12000 sq ft of Corian) and the procedures are ready so we are about to be off a running. We just need to be approved for the final sign off and the job begins. Thanks again.
    Dec 2012
    Bedford, NH
    1,683
    Pictures please!
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    Oct 2011
    Cortland NY
    238
    I'll get a picture or two soon. The install date was pushed out another month so here we sit. I'll see what I can do to let you all in on the process.
  1. Router table router recommendations - What are your experiences?
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 11-11-2012, 03:27 PM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 01:02 AM
  3. Replies: 0
    Last Post: 09-01-2010, 05:29 PM
  4. Router Table Router and Lift
    Last Post: 10-08-2008, 06:21 AM
  5. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
