Well the Yellow heart took some time, but its all set
As you can see in the picture I taped it all together so when I get ready to do the outline on the chest
Next is to mark out the area on the chest
Next set your inlay as it is going to be marked out, about 1 1/2 -2" so you can see what needs to be done with the knots
Next Draw a circle around your Inlay area
In the next Picture you can see I have 7 knots to stabilize before I do my mark out for the inlay, if you do not do this now it will give you problems in the long run
Well as anyone that has worked with Cedar knows that the knots can be a PITA so take care of them now I am using Thin CA an Medium CA to stabilize them
Keep filling in the areas with the thin first so it can soak in, then the knots that have little splits use the Medium CA to fill the voids
Once its all filled let it set until dry I do not use any Accerator I just let dry on its own , once its dry sand off any high spots in the CA areas
Next set your inlay where its going an trace around it , I use a .5 mm pencil to do this
I be posting again tomorrow, when I'm back at it
