Art Mulder
- London, Ontario
With the drawers you may want some steel support above them, even at 1" thick for the top I'd suspect it will flex without a full rail below if anyone sits on it.
Maybe I should just try for a thicker top and skip that front stretcher.
According to the sagulator (http://www.woodbin.com/calcs/sagulator.htm)
- 1" thick black cherry, 22" wide, spanning 37.5" will sag .04" with a 400lb load on the center (ie: two adults standing on it)
That is 1/25 of an inch, by the way
- If I increase it to 1-1/2" thick top, the calculated sag drops to .01" under the same conditions
- I just realize I made a mistake -- I do have a back rail behind the drawers, so let me redo this with a 19-1/2" width.
- 1" thick = sag of .05" (1/20 of an inch) I don't get that, as intuitive it should be less... I suspect the sagulator is intended for shelving, so it is assuming that the shelf is NOT attached at the back. And yes, I just did some googling which confirms that it does NOT make any allowance for the shelf being attached at the back.
So I think I'm going to go back and get rid of that front rail. (and maybe see if I can get the top 1-1/4 or 1-1/2" thick...)
...art
