- Austintown, Ohio
One way to eliminate the rust issue is to coat the tank with a ceramic coating product. Commonly used on gas tanks for classic car restoration. Since the air outlet is on the top of the compressor...no worries about clogging.
Good luck with rolling the tank around to slosh the coating all over it for good coverage. I assume you'd need to leave the tank sit - unused - with all its orifices open so the coating can dry before pressurizing.
Actually, with regular draining, an uncoated tank should last for decades.
Ambient conditions, of course, will affect tank life. High humidity, and coastal 'salt air' will enhance corrosion. In the high desert, a tank oughtta last nearly forever.
