with the christmas signs out of the way, started in on the cribbage board for the fair. removed the setup for the signs, and rerigged for the cribbage board. i first cut the skunk lines, along with the s. then, as they used the same 20 degree bit, started the engraving of the body. with that done, switched to a 30 degree bit for the lettering. with the lettering out of the way, swapped bits again, to a 1/8" end mill, for drilling the holes. a couple of close calls with this one, the first was when i hit return to zero, instead of reset zero. no damage there. the other was when i was almost finished drilling the holes, when a board i was picking up slipped out of my hand, landed on a curl of cords, one of which happened to be resting on the on/off switch of the power strip (on the floor, haven't found a permanent home for it yet), and turned it off, cutting off power to everything. after a painstaking repositioning of the new zero, started drilling again. this time the cnc gods were smiling on me, as the bit hit the first hole (and all the rest) dead center. that extended the work time by another hour or so, but got away clean on that one. today, i hit it with the walnut gel stain, and the effect was what i thought it would be. now all that is left to do, is hit the back with dewaxed shellac, then the back and sides with the gel stain, another coat of dewaxed shellac, and 2-3 coats of clear shellac.
