Auto-leveling Questions
Bill Arnold
1974
Thomasville, GA
It looks like auto-leveling is working on my A8 now that I got the firmware updated, etc. A couple of questions:
The default leveling in Skynet is LINEAR but some think BILINEAR is better. What say you?
//#define AUTO_BED_LEVELING_3POINT
#define AUTO_BED_LEVELING_LINEAR
//#define AUTO_BED_LEVELING_BILINEAR
To adjust the offset between the auto-level reading and the actual position of the hot end, is G92 the correct command? How much offset do you use?
Thanks!
I left my z offset at 0 in the firmware, then changed it in the menu on the printer, then stored it in the eeprom.
He covers how to figure out the offset in the video below, but I have my sensor mounted about 1/4" above the nozzle, and it picks up the bed when the nozzle is about 1mm away. I then zero (G28), run the auto level (G29, then set the offset after the auto level runs. Basically tell the printer to go to a height of 0 (G1 Z0), then use drop down .1mm at a time until you are touching your paper as you would normally do to calibrate it. I then go to Control>>Motion>>Z offset(?) and adjust that stored number to be the amount (mine is about -.9mm). Then go back up one level in the menu (under Control still) and Store the values in eeprom. You should be able to run G28 and G29 again. I then set Z to 1mm and step down .1mm at a time to verify the offset is still correct.
https://www.youtube.com/watch?v=rP12HVm-aKA
I left the firmware settings as they were in Skynet.
I found that Octoprint has a plugin for reading and writing the Marlin eeprom values. When it didn't appear that G92 was doing anything, I began tweaking the Z-Probe Offset value. I have it at -1.62mm now. Test prints are looking pretty good so far. My test probe is about 5-6mm higher than the nozzle. I adjusted the trimmer in the end of the probe until I got consistent illumination of the LED on the glass.
Cool. I've been having really good luck with mine since replacing the carriage plate. I did have an adhesion issue the other day, but don't blame the auto level as it was even all the way around. I had decided to play with the temps with the filament I was using and made a bad choice to not run warmer on the first layer. The entire right row of parts pretty much popped loose one at a time over the last few hours of the print. Eventually the spaghetti blob got big enough it knocked my X axis off by about 1mm and ruined the rest of them.
Edit: BTW, the linear vs bilinear may need to be changed if you're finding areas of your bed aren't quite printing correctly due to a twisted bed. I'm running linear and minimized my readings to just the 4 corners since my bed seems to be flat now. The x/z axis needs to be parallel to the table also from what I've found, which is easy to do now that you have the dial gauge adapter.
I'll have to look at the higher temp on the first layer and see what happens.
I ran a test cube box and got the best bottom layer ever. Dimensions of the 20x20x20 box came out at 19.98X by 20.02Y by 20.00Z. Not gonna try for anything better - yet!
On the linear vs bilinear, I got the same idea from what I read. Since I'm using glass, I'm pretty sure it's flat so I'll stay with linear. I printed a set of three test squares that are 153mm, 143mm and 133mm, so they cover a lot of territory. They look perfect all around the plate.
