Stuart Ablett
- Tokyo Japan
I'm working on some stuff for the Liquor shop, we got a bunch of new shelving for displaying tobbaco products. They are supposed to be behind the counter, out of reach of the customer, but we have to put them on the counter, because of space limitations. The problem is they will be VERY easy to steal from. I'm making some flip up doors and some flip up box tops, I know it does not make sense at the moment, pics will follow.
I've not really worked much with Plexiglass, and glueing it is kind of a Bugaboo for me. The edge off the tablesaw is too rough, so I have to set up my router table like a mini jointer. Well one of the problems with having your router table in the wing of your table saw is you cannot easily go from one machine to the other. To solve this I banged together a small router table using an old router table plate I have that is mounted on a router I don't use much. It may not be pretty but it should work. Took me just over an hour, worth the time I think.
Cheers
Sent from my WAS-LX2J using Tapatalk
