- falcon heights, minnesota
looks like cabin fever is setting in already my friends. i'm gonna be so busy when the shop opens up next spring....
You don't even know what cabin fever is LOL I have only been home a week and am going stir crazy
...That pesky broken right arm doen't have the strength to hold or open the chainmail rings...
Definitely committed to this now. ordered 640 of the finest cribbage pegs that Chinese prison labor can make tonight.
with the new spindle, and mounting bracket, i've had to rethink how i was going to mount the laser. it seems that luck has stopped by this way. with the new bracket having three pre-tapped holes on the side opposite the side that secures the spindle in the mount. after a bit of thought (thus complicating matters), the easiest way, was the way that works best. a 2" x 2" bit of 90 degree aluminum angle stock, with holes drilled to mount on the spindle mount, makes the 90 degree turn across the front of the spindle mount, where a couple of holes will be drilled to mount the laser.
