Allen Bookout
- Punta Gorda, Florida
As you know there are tons of solar pool heaters here and my thoughts are based on what I know about our systems. I know that much information from here does not apply to your area due to the extreme difference in the weather so I will eliminate anything that would not apply to you.
First I would not try to build my own solar panels. The commerical panels are very efficient and UV resistant. You could spend a large percentage of what a commerical panel would cost and only get a small percentage of the heat available. The commerical panels will probably last much longer than anything that an individual might construct.
The only other point that I would make is that I would not attach them to my roof if there is any other option. You mentioned being pounded by weather and winds and if these panels start tearing off you could have some expensive damage to your roof, not to mention any water damage inside your house. There are a lot of new regulations here due to the damage caused by roof mounted solar panels. Of course we live in hurricane country but your winter winds might not be a whole lot less.
Some companys gurantee the hold down systems up to a certain wind speed but I say take those sort of things with a grain of salt.
Down here the solar systems work incredable well and I would not do without mine but I only use mine for heating the pool. For some reason water heater systems are very rare. I do no know why unless it is not cost effective.
Good luck in your quest! Allen
