Marty? Marty?
Uh-oh, no signs of life.
Poor guy ... he musta thrown that switch.
Not to worry Kerry...
I did indeed throw the switch to 10 amp...it made no noticable difference.
But...while I was in town getting more aliigator clips to be able to 'wire up' four clamps simultaneously, I also picked up a better ingredient for the broth:
What I picked up this morning wasn't in fact 'Washing Soda'...although I thought it was. It was actually Arm & Hammer laundry detergent with Sodium Carbonate as one of the many ingredients. Once I did some more research, and figured out what the sodium carbonate was supposed to be doing...and the fact that baking soda has a pH of 8 (7 being neutral) whilst Washing Soda has a pH of almost 11, I realized my dilute detergent bath wasn't going to cut it.
But, thanks to playing with the chemistry for our pool, I knew that there was a pH increaser that was used in pools. I went outside, looked at the label...and sure 'nuf...100% Sodium Carbonate! I just didn't have enough to spice up the soup. But I was right across from the pool store when I was getting the alligator clips...problem solved!
Before I added three more clamps in the bath, I dumped out the soap and refilled the poly-cart with water and pH increaser. I then added my rebar and the four JLT clamps.
As soon as I plugged in the charger, I knew the ph increaser was making a difference. The conductivity of the water increased four fold...(or there abouts
). Looking at the ampmeter on the charger, the bath was now drawing a full 10 amps. Whereas with the soap soup, it was drawing a mere 2-3 amps...even on the 10 amp setting. I think I have a better concoction now!
Here are a few shots showing where I just left it when I shut down the shop.
Here are all four clamps...wired together and bathing comfortably:
And here are a few shots showing that you can actually see glue floating to the top of the soup:
I'm not getting the nasty brown scummy looking bubbles that I saw in Stu's pictures, as well as pictures on other sites. But I'm thinking that might be caused by the fact that there really isn't all that much rust on the clamps...just LOADS of glue.
All in all, I think it's working. I guess we'll find out in the morning when I remove the four clamps and rinse them off to post pictures...
Marty,
James and I were looking at those pictures. James kept saying "Wow! That's so tool!" (he can't quite make the "C" sound yet, but he's working on it.) Meanwhile, I was trying to figure out what in the heck the big deal was, since I'd never seen anything like that before. Then I saw the last picture, with the clamps extended, and it was my turn to say "whoa, that's so cool!"
Bill, take a look at the link to the JLT site I posted. That shows the rack actually in use, with panels in the clamps. That gives you a much better idea of what the rack/clamps are capable of. WAY better than Besseys
On the electrolysis, I think I had a case of too much info from surfing too many sites. One of them said the battery charger I'd gotten for the purpose simply would not work. Another said the entire piece to be cleaned had to be completely submerged. I guess that was wrong on both counts...
Bill
Well, I did an equal amount of surfing...but decided to cull out what I wanted to hear
I read that parts CAN be partially cleaned, and then flipped over to clean the tops...assuming the bathtub is too small to contain the entire piece. As for the charger...I think mine is working...but as I said, we'll see in the morning.
Thanks again to everyone for the idea...
- Marty -
