- ABQ NM
Shaz, check your camera and see if it has a preset for "Incandescent Light". That should get you more realistic colors. Did the flash go off on either of the two pics you posted?
what can I do in a room with all incandescent lighting to get the color of the first photo, in fact, How did I get that one, and hwo did I get this one? . Too many things to remember.
Shaz
Shaz,
'bout as good as I can do with my limited "iPhoto" program.
Not quite the "halloween pumpkin" look, but not the real McCoy either...
Hi Greg ,
You know each and every effort is appreciated!
Thank you.
Shaz
Dear Vaughn, Hi ,
This question is something I do not remember, however your input has helped lead me to the photos posted at the end of this note....S
The first pic looks like it was taken with the flash. The camera "knows" what color of light its flash unit puts out, so it can do a good job of white-balancing for it, especially if the flash with provide most/all of the light for the shot.
Hi Kerry ,
Always appreciate your input. The concept of the flash correcting things is an important realization. Vaughn mentioned "flash" and you further explain it. I think you have hit the nail, Rather than my finger!
Having all-incandescent light is definitely better than having mixed light sources ... which can be a real pain.
Have you been there? Sosunds like it...
Most digital cameras have a built-in set of white balance settings, usually for incandescent, fluorescent, daylight, etc. The icon for the one you're looking for probably shows a standard light bulb "shining". It might even have a label of "Tungsten" or "Incandescent".
Mine has that white balance thing, I have seen it!,,, but I'm too lazy to read the instructions, thus for 7 years I have been mentally without that feature. I never did get another camera as I figured out that squeeze clamps at first, now, gum bands from broccoli stalks will hold the battery compartment lid closed.!
If you don't want to take a chance mixing the flash with other light, AND your camera has a "Custom White Balance" feature, you can get the best setting for the ambient light by:
* Holding a piece of white paper in the same light that you'll be shooting inQuestions? OK, but now it's ... hmmm ... Stu's turn?
* Zooming in (if need be) to fill the viewer with the paper (as much as possible), and
* Pressing the appropriate button to set the Custom White Balance
This is very clear info. I have had several 35 mm since the 70's and this makes sense, however since the digital I have expected it to cook me dinner, automatically. I am losing weight!
Hi Ed ,That turned out great!!!
Hi Tod ,nice work shaz!
Hi Greg ,Thanks so much for the journey !!!
Hi Chris ,it turned out beautiful shaz. very very nice. thanks again for takin us on the journey though this build.
