Ron, I assume you mean the one with the yellow wood and the ebony center. What I did was glue the yellowheart to the maple before I turned it. Once I had the blank round, I then turned the yellow part smaller using a bowl gouge. I also thinned the yellowheart because it was 4/4 when I started. Then I drilled the center and glued in the ebony. Next, I parted off the top and glued it to a board with cardboard between it and the board - this is to hold it while I carve it. Then carved it.Quick question Mike
It looks like the flower is a different wood and was glued on after carving. Is this correct?
(post#9)
Yes, just as long as you can hold it down so you can do the carving. I've made some boxes with hollowed out lids and what I do is leave enough wood in the center of the top that I can put a long screw up from my board into the top to hold it. A jam chuck might work but you often put a fair amount of force on it when carving so be careful.Thanks Mike
I'm not a member on SMC, so I can't see the images.
But I get the idea, it's similar to the way I do a basic inlay on boxes and add finials to ornaments.
Because of the way I do boxes I won't be able to use a glue board, but I have an idea that might work using a jam chuck.
Hi Ron!
It doesn't look wrong to me, from my point of view it is only unfinished.
Give it a second thought, make some tweaks, look at its reflection on a mirror you'll see what is wrong inmediately ( it is a good trick), and you'll see that it comes along nicely.
Do not give up!!
Very nice first attempt. I would have made the center a bit smaller but that's just my way of looking at it.So here is my misguided attempt at carving.
Believe me when I say it looks better in the picture than in real life
