Jim Koepke
I am new here…
Looking at the images, that is not a Stanley plane.
I have not seen a Stanley with that type of frog mount.
If it was from the Stanley Sweet Hart period, there are a lot of things that would be different.
1) The frog would have a notch in the front edge to align with a rib cast in the base.
2) Bailey would be cast into the toe area.
3) The knurling on the brass adjuster is diagonal, Stanley only did this from 1946-1948. The frog from those years was different.
The lateral lever is like those on Sargent planes.
These are sources for more information:
http://www.brasscityrecords.com/toolworks/graphics/plane id.html
http://primeshop.com/access/woodwork/stanleyplane/pftsynch.htm
https://home.comcast.net/~rarebear/planes101/typing/typing.htm
It is my understanding that the last site is undergoing corrections to the errors that occur in such a large project.
The problem being encountered with the blade adjustment may be due to the cap iron being a Stanley. If the adjustment slot is in the wrong position in relation to the pawl, it will never work quite right. This could be off by just a fraction of an inch and cause all kinds of havoc.
jim
jim
