Rob Keeble
- GTA Ontario Canada
Someone please correct me if I have it wrong but why can you not make a consistent dowel on your lathe if you set up a router on a jig that will run the length of the lathe, with the router parallel to the horizontal axis and a bit fixe at the distance from the block of wood that is to be turned into a dowel. Then you switch on the router and slide it along the lather bed while the lather rotates. With the router being in a fixed position from the spinning block of wood it can only cut to the set depth which will be worked out to result in the diameter of dowel wanted.
Once setup this could be used to churn out dowels and then dismantled until next time.
I have seen pictures of this setup being used to put flutes in a spindle.
Surley it can be used to make a consistent dowel.
