Tom Baugues
- Lafayette, Indiana
I have been reading all winter long about people using these carbide tools to make pens. Well its finally getting warm outside and I'm back in the shop so I decided to try to make one myself. I decided to try a round cutter first. I looked around on e-bay and bought a 12mm cutter ($4.00 shipped to my door). I then found a 3/8" stainless steel shaft and cut a recess on the end and drilled and tapped hole for cutter screw. Gathered up some scrap wood from my shop (Sassafras, Padauk and Purpleheart). Turned the wood to shape, drilled a hole for the shaft and glued in with epoxy. Added a copper plumbing fitting (.58 cents) and finished with some clear shellac. The Padauk and Purpleheart got much darker than I had hoped for but in the end It looks like it should work well. Overall length is about 17" with about 6" of shaft sticking out
I hope to try it out this weekend.
Total cost to build....less than $5.00. Love it when a plan comes together!
Next up is a square radius cutter and maybe some larger cutters on 1/2" shafts for cutting out bowls.
