That set up is worth a try, Dave.
Plus 1 on Vaughn's excellent suggestion. Also, if you want to experiment, or if you have something too big for that box, try setting up your own DIY photo booth. In addition to a camera, a simple set up for most turned things involves a light source, something to diffuse the light, and a back ground (gradient preferred). I use two of these cheap
aluminum reflectors from Lowe's and add daylight LED bulbs. One light gets clamped up high on one side, the second gets clamped low on the other side. I use a gradient background similar to
this one, with a light colored foreground fading to a darker grey background, but a piece of light grey mat board works too. To diffuse the light and help eliminate hot spots I invested in a fairly large pop up photo tent because I do big stuff, plus I take a lot of pictures for the missus' Etsy store. Anything that diffuses the light will work...a white sheet draped over a frame, a box made out of that cheap 1" white Styrofoam from the big box...I used a cheap Styrofoam cooler from 7-11 for a long time.
Set up your camera on a tripod, play with the lighting, take a bunch of shots, open up the pics in something like
IrfanView, crop, sharpen, auto adjust colors, done! Not the greatest examples, but you get the idea.
