larry merlau
- Delton, Michigan
hey frank that walnut that dan took was from you???? it had his name on it??? and what ever is the case i can find some knife handle material if your looking for some..
I opened the box on the kitchen dining table and immediately got pushed aside as LOML wanted to look too... she had as much fun going through the box as I did... I then took it to the shop so I could go through it more carefully... what a haul.. must have been close to 100 pieces in the box... didn't count, but I took out about 20-25 pieces and put back at least that many or more from my stash..
1. The box
2. Contents spread out
3. What I took out
4. What I put in
I'll get it back in the mail and on down the line in a day or so... not planning any trips into town for until after my next show this weekend.
I thought we only had one going and I shipped it to you back in June or July...
Has another started I didn't even see or is the this the late one and you are one of the first to report..
I guess if there are names on the list then it's a 2nd lap....or a different swap..
Frank is there a list of where it's going in the box?
Am I on it?
just out of curiosity how many are out there, and will one swing by central ny again?
Just this one box here.
And, nowhere near New Yawk.
Two pics. One of all the blanks in the box now out of box.
Other is of the blanks I removed from the box, stabilized, then will repack to send along to others. Some maple, spalted maple, box elder, willow and other stuff in there. All should benefit from the stable process.
Frank,
I know you've posted your process before, but too lazy to look for it this morning... how do you stabilize your blanks... some of those blanks in the bread pan have my initials on them, some of the spalted maple, the willow and box elder... I have a box of the maple probably close to or maybe over 100 blanks.... is your process something that could be done relatively easy, or does it require pressure or vacuum.. I don't have access to either. My box elder is about beyond the use stage... it would also benefit from the stabilizing process.
