- Reno NV
Does the bell end go towards or away from the panel?
Thanks!
Thanks!
Here, technically, you aren't supposed to put electric and water in the same trench. I think you made the right call on the bell ends.
Here, technically, you aren't supposed to put electric and water in the same trench...
Here, it's allowed. My shop has electric, gas, and water lines all in the same trench.
(I guess if the electric shorts and catches the plastic gas line on fire, the melting water line will put the fire out...)
Just remember what way you put them in. When your pulling the wire in you will want to be pulling it out of the straight end and into the bell. Other way around and the wire will hang on the end of the pipe.
Good to know. I did get the 3/4" conduit instead of the 1/2, so hopefully that, with a good amount of lube will make things easy.
But you know how I am with projects, might take a while before I get around to it.
Heh, Well far too late for all of the good advice...
