Thanks Bill
That is kind of what I have in mind, but way bigger!
I am going to use a dumpable hopper instead of a trailor as I have the tractor and forks, so one less piece of equipment to maintain, and I think it will be faster. I will be dumping in the compose hole on site so will be a short run. Tractor will lift 2000# so it can be pretty good sized. Figure on welding it up in a taper so it will dump easy. All of the equipment will be inside a structure to conserve heat, and hide it from view from my house.
Made contact with Bill Pentz today so I will see where that goes. Been playing tag. He may tell me my ideas are junk? I have been thinking of a two blower/cyclone system so I don't have to run a huge motor all the time, but still be able to run both should I pick up a wide belt. I often run two or three machines at a time when I am prepping stock, so when I am doing that I can run both sides as well.
The other thing about the split system is that I can probably run them with single phase motors, saving my 50 hp three phase limit[converter size] for machinery.
