When I priced those they cost almost as much as a cabinet type table saw would here in the US (more than most used), I bought a dado set from Forrest (6" dia instead of the 7" the hammer/felder of which is the very biggest grooving blade you can put on without hitting some hardware; regular blades can be up to 300mm/12") which wasn't cheap either but was a whole lot less than the Felder one. In order to support the dado tooling you need to order the hammer saws with an "extended arbor" (Preparation for Dado tooling up to ¾” - is how it's listed on the website) which is a factory option and can't be retrofit on later, that's now (again according to the website) a standard option on saws shipped to the US, but I don't know if it is over there or not, it might be since the US is such a large part of the market it would probably make sense to make them all the same. There is another part you put over the saw blade to clamp it down (basically an oversized washer) that is different for regular blades and dado blades as well (the regular one is thicker and then there is a thinner one for the thicker dado tooling as well as two different lengths of bolts). The plethora of options on the hammer tools can be a bit confusing (for example there are a number of crosscut fence type accessories and I'm still not sure about some of them).
I have the option for the incisor/scoring blade but have never put a blade on it
. It came stock on the package deal I got otherwise I probably wouldn't have gotten it. For normal plywood I get basically tear out free cuts with the blade I bought from tenryu (the Felder blade as shipped wasn't as clean), I could see it being useful if you were cutting a bunch of melamine or maybe prefinished plywood or were doing a lot of euro style cabinetry with no face frames to hide any small oops. For solid wood is not really useful.
