Frank Pellow
- Toronto, Ontario, CANADA
(part 1 of 5)
I started building a woodworking bench just about this time last year and reported progress in the thread: http://familywoodworking.org/forums/showthread.php?t=2984
That work stopped in early June when I packed it in for the summer.
Early this year, I picked up the project again and now the bench is (almost) complete and I have started to use it:
I will continue the “story” with extracts from my weekly journal. Also I will pick up the number of the steps from where I left off last June.
2008 Jan 20:
22) The first task at hand is to finish drilling all the dog holes in the bench top. I made a simple jig that speeded up the process:
Compare this to the clamping both on top and underneath the bench that I was doing before -as per the photos I showed in this journal last June:
This time I am screwing a temporary sacrficial piece of wood underneather the spots where the drill will emerge. Things are going much faster and about half the holes are now drilled.
2008 Jan 27:
23) I worked a little bit on the woodworking bench and almost all the dog holes are now drilled. There was a problem because the jig from Lee Valley that I was using broke due to metal fatigue. I will probably take it back. I devised my own simple jig which seems to work OK.
2008 Jan 20:
2008 Jan 27:
yet.
