I designed a new dust boot this morning due to my never ending quest to get dust collection for the CNC and discovered another useful feature in Fusion. It will provide a setup sheet to shows you exactly what you have set up to run the part. I like it in that it not only shows you the part but also the size of the stock you were planning on, the tools used in the process and the feed rates and spindle speed you programmed into the part to be made. This is useful in my case since I do my programming in my office and then run the program out in the shop. That way I will know exactly how I want to fasten the stock to table and with each tool change what tool I planed I used for each operation.
