no worries leo, been a long day. the laser set up is it's own machine. a chinese laser set up that the wife
bought for me, and i added the laser from jtech photonics. turns out the original chinese laser, advertised as 15 watt, was barely 6 watt for output. the 15 watt was the power going into the laser. if you are looking to set up something small, so you won't have to break out the death star, or fire up the cnc, i would suggest there is a site out there, similar to openbuilds, whose name escapes me, that has a boatload of plans that can be adapted to make a small laser setup, and all you need do, is get the rails, and such, for building the framework. then give jtech a call, to see what you need as far as the laser, and other bits to run it. as far as pictures go, i found the sweet spot for me, in lightburn, is 254 dpi, with a jarvis dither, 80 ipm, and 100% power. i have the 7 watt (and it is 7 watt output) pro version, and the focal distance is 1/8 inch from the bottom of the shroud, and jtech supplies a plastic 'coin' that is just that thick to measure with. my set up is 26 inches wide, by 22 inches deep, the bench is on a mobile platform that is 24 x 48 inches. i almost forgot, the laser shroud is on a magnetic back, and it is attached to a metal plate that is on the original z axis.
