I started out with the intent of just doing the submarine half hull but after a few suggested it i convinced my self that I wanted to make the whole hull so now I have the design complete I am ready to make some chips but I am running into a bit of a snag. If I make the two halves out of the same piece of stock by flipping it I am afraid won't be getting a perfect match up of the zero point and this will create to much misalignment form one side to the other since I don't have a rotary axis. I think the best solution is to make each piece from separate stock and then glue the two half together. This might be the cleanest solution at least until I can get a rotary axis.
The good news is I have reduced my machining time to under 90 minutes per half at 100 IPM...
